Old 10-12-2018, 08:48 PM   #4
dghii
well, my end of summer PM work is almost done, I have a new AOS because I thought that was the source of my oil leak but it was not. Oil leak on passenger side dripping onto OXY sensor...but can you replace the AOS without removing the intake assembly ??...I sure cannot even see the bolts from the top or bottom
Don't know if or when you've done your spark plug tubes or O-rings but I experienced a slight oil leak a couple of years ago that turned out to be O-rings. I initially dismissed the possibility as i had done tubes and O-rings at 90K miles. At 130K, after a few drops of oil and a hot oil smell as oil was dripping on exhaust, I replaced the O-rings again and problem was solved.
dghii is online now   Reply With Quote
