Old 09-19-2018, 03:06 PM   #4
speedyspaghetti
Originally Posted by paulofto View Post
The RMS is a no brainer and I'm not sure if the kit includes the release bearing or not. Also, scrutize the flywheel. Not every mechanic does but while you are in there . . . . Pricy but while you are in there . . .
I had the whole works done plus a brake/clutch fluid change 2 years ago and it came to ~$5K CDN so using today's exchange rate that is ~$3,800 USD. So considering the flywheel your $3,349 doesn't sound too bad.
PS Mine has the Sachs and it works beautifully.
He said the RMS is no problem, but also suggested the EPS RMS solution kit - does anyone have experience with this? Is it worth the cost over just replacing with an oem RMS?
speedyspaghetti is offline   Reply With Quote
