Old 06-15-2018, 06:51 PM   #1
The Radium King
The Radium King's Avatar
And they only fit Porsche/TRW arms, or aftermarket with the exact bushing diameters, Meyle has slightly larger and so these won't work with them.
I think powerflex makes an eccentric poly bushing... Much better pricing...
Edit: https://powerflexusa.com/porsche996fronttrackcontrolarminnerBushing-pff57-801-1-2.aspx
Not much better pricing
still $150 less - thanks for that find. i guess i was not aware of this because everybody says that the gt3 arms are the way to go. but for a street/track application all you really need is a little bit more, so something like this should do the trick. i'm currently around -2.8 at the front at m030 ride height, eccentrics full out and camber plates full in - how much more negative camber do you think 6mm will get me?
