Old 06-05-2018, 08:56 PM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
Originally Posted by AZ986S View Post
Another way to do it is to tap into the High Speed and Low Speed relay coil ground wires (pin 86) and use an ON/OFF switch to route to ground. That way you are handling low power controls. That's how I did it and a few others as well.
Not to hijack the thread, but thats what I'm doing with the fan relays, but I want to install an OEM switch to control the on/off function, which requires a latching relaying since OEM switched are momentary.
