Old 01-10-2018, 08:11 AM   #1
gabedrummin
gabedrummin's Avatar
I agree with the wear, so. Aluminium oil pump housing running hardened steel gears. Low pressure is only at idle as soon as rpm increase so dose pressure. So why couldn't it
be the pump walls are slightly wore. At low rpm pressure is lost between gears and pump wall ?I cant believe no one has tried to re build or replace the pump . If it had low pressure across the entire rpm range then yes rod and main bearings shot.Or knocking rods .
gabedrummin is offline   Reply With Quote
