Old 01-08-2018, 07:13 PM   #19
ymkmkrz
Originally Posted by TomKimbrough View Post
I have a '99 Boxster with 5-speed manual. I want to change the gear knob, but I can't locate any Allen set screw as mentioned in my Bentley service manual. I also can't simply pull it off as Pelican Parts mentions. Any suggestions??
The frame just lifts up. Take a good plastic interior tool or a plastic putty knife and work it off. If you are planning to use a regular knob you will need an adapter. The shifter itself is rectangular. There are adapters to make them round but you could have some Vibration issues. The shift knob assembly includes a frame, the leather boot and a knob. The stock assembly has the boot made into the knob. You
Can find a frame and a separate boot on ebay and use whatever you want along with the adapter I Mentioned.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
