Old 11-21-2017, 07:02 AM   #1
That986
Originally Posted by DWBOX2000 View Post
There is a faint banging around noise is my right rear quarter when driving. Do strut mounts usually go out in pairs or can one last considerably longer? My left side is good. I just check the torque, all are ok. I jacked car up and shook everything around, no noise. I then put a 2x4 under tire and bounced up and down, noise appeared. Left side doesn't do. Would having a bad sealing ring be likely another possible cause. I noticed it was in rough shape when I had struts off a year or so ago. I replaced the left side. I know, dumb move not replacing when I had the chance.
You only replaced one shock, not the pair? Bet that feels good at the back.
Are you sure it's not your track control arms, they knock around.
That986 is offline   Reply With Quote
