Old 10-02-2017, 08:56 AM   #1
BoxsterLS376
You have a coolant leak, likely a bad water pump. They are known to fail on these. That is your biggest problem, the oil and axles are fairly common as well and won't cause problems in the near future, that water pump however will leave you high and dry so I recommend getting a new water pump and T-Stat.
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
BoxsterLS376 is offline   Reply With Quote
