Old 05-17-2017, 04:51 AM   #2
algiorda
I am No. 1348
algiorda's Avatar
Originally Posted by joecal View Post
I agree, that sounds like a great deal if it's in nice condition and with low miles. I would ask exactly what was done for the 6K he recently spent. Good luck! One more thing ask if the IMS bearing was replaced and the rear main seal, hopefully that was part of the 6K he spent.
To Joecal's point; if you check either the drivers door jam or rear trunk lid, you will find a sticker certifying the LN Bearing was installed, if it's not there, then it could still have a new bearing, just not an LN Bearing.
Also, a dealer PPI runs around $300, and an Independent Certified Porsche Mechanic will charge an Est. $150. Not all PPI's are the same, some do leak down tests, others don't. Some do camshaft deviation tests others don't. So make sure you ask specifically what information the PPI will provide.
I'll start off the list of Items to check for wear and tear:
Water Pump
Serpentine Belt
Pulleys
Coolant Tank
Air Oil Separator (AOS)
Rear Main Seal (RMS)
Ignition Switch
CV Boots
Brakes/Rotors
Try to get a sense from the PO on how the car was maintained. Frequent Oil Changes, Service Records, did PO do any of his own mainteanance, does it have a magnetic oil drain plug, does it have a custom spin on oil filter?
Current: 2004 Boxster S 550 Spyder Anniversary Edition (BSSE)
algiorda is offline   Reply With Quote
