My passenger side headlight assembly was tilted back more than it should of been. The top was fine but the hole for the headlight washer was about a 1/4 of an inch above the washer nozzles. I thought it was a big job to adjust the housing but after searching the forum I realized it supposed to be fairly easy. It took me quite a while to finally get it what I call perfect. Later I thought check to see if the lights work. Now none do ☹
I didn't unplug the main connector wires.
I was wanting an opinion. I hate to take it out again. Would it be easier to remove the inner fender liner and see what happened under there?
Thanks in advance.
