Old 04-13-2017, 01:57 PM   #24
JayG
On the slippery slope
JayG's Avatar
Originally Posted by Boxtaboy View Post
Technically, I don't think the shop is in the wrong because you didn't specify you wanted a specific type of LN Bearing. If the shop knows they don't have the upgraded tooling to install the Pro model, they won't come out and tell you that option cause you only specified a LN. Is it totally honest, no- but let's be realistic...not everyone is, and they have to make money. It's like asking a dealer to use Mobil 1 to change your oil. If you don't specify 0w-40, they can fill with Mobil 5w-50 if they got that in stock for cheap, and still would've followed your orders.
Do you have a right to be upset though?- yes, but you're part to blame too for finding out the difference after the fact. The shop's job is to complete jobs, not consult you for the best option necessarily. Would it be nice if they did?...yeah
Bullshyt
A good shop absolutely should be recommending and discussing with you the options and what they feel is the best option for your needs
They should tell you exactly what they will be doing and what parts they will be using. Using your example of an oil change, they must ask and let you know the options and what oil they will be putting in
The ultimate decision is yours, not the shop
Case in point
I just had a torn CV boot and my mechanic gave me 3 options
1- replace the boot and rebuild the CV
2 - replace the axle with an aftermarket one
3 - replace the axle with a factory one
He gave me the costs ans well as the pros and cons of each choice and I decided on how I would spend my $$
2004 996 Targa Tip
Instructor - San Diego region
