Old 03-20-2017, 03:47 PM   #11
itskenallen
itskenallen's Avatar
Do you just want the fog lights on at all times when the ignition is on?
If so, pull the headlight switch and connect a jumper wire between the violet wire and the yellow with white stripe wire, which are both on the headlight switch connector (back of switch - do not sever them from the switch, just jump between them).
That will do it on UK cars.
You sir, are a genius. Thank you.
With this mod, will the fogs switch off when the running lights are switched on like the relay hack?
Sent from my SM-G928F using Tapatalk
itskenallen is offline   Reply With Quote
