Old 02-09-2017, 11:29 PM   #2
geraintthomas
geraintthomas's Avatar
No!
The wording on that page is misleading. They were referring to their wiring that they added when they said "Red = Key-In Accessory, Orange = Illumination".
The orange wire is the 12V + accessory wire on the ignition switch. You can also tap fuse E1 as this is where that orange wire goes to.
You'll need to tap a different wire for dimming illumination (grey with blue stripe - can be found on instrument cluster connector if you don't have one behind the stereo).
Right! Perfect, thank you. The fuse will be easier as I'm already tapped into E8, so I just need to swap it thanks man.
Change the ignition switch while you are in there ? (VW part number)
Why?
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
