Thank you! I just tried that and unfortunately no luck. The dome and door lights are not working either which made me think it was a fuse but I can't find one that isn't good. I don't know which fuse it is on a 1998 so I used a test light on both sides of each fuse in the box. It all worked before I changed the ignition switch. Last night I put the original switch back in but it must now be completely bad because nothing works with the original switch now. I'm wondering if maybe the replacement switch which was an aftermarket one is just no good as well
