Old 01-22-2017, 11:31 PM   #1
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by KRAM36 View Post
90038502504 - HEXAGON-HEAD SCREW 6 - ES#1377250 Need 4 of these
N01152427 - WASHER - ES#1882232 Need 4 of these
http://www.************************************.com/ES1511639/ Need 2 of these
99711031900 - Throttle Body Gasket - ES#1498080 Need 1 of these
99711041603 - DISTRIBUTOR TUBE - ES#1498085 Need 1 of these
This silicone hose to connect your TB to your intake pipe.
Racing Silicone Hose Elbow Coupler Pipe 3 15" to 3 15" 90 Degree ID 80 mm Black | eBay
This silicone hose to connect your your MAF housing to the intake pipe
Black 3" 3 0" 45 Degree Elbow Silicone Hose Coupler 76mm Intercooler Pipe Turbo | eBay
You will need 2 of these to clamp the silicone hose to the TB and to your intake pipe.
1pc 3" 76mm Turbo Silicone Hose T Bolt Clamp 83mm 91mm 301 Stainless Steel | eBay
Get these to mount inside your intake pipe that goes to your TB, only 2 will fit in there, but the set comes with 4. Adds strength to it as it's flimsy.
One Set of 4 Hub Centric Rings Size 71 5mm to 75mm | eBay
You can probably reuse your plenum gaskets, but I went ahead and bought 3. I could have reused mine.
Porsche Boxster s Intake Manifold Gasket Manifold to Head Set of 3 Genuine | eBay
Search eBay for a used 987 air box. I got mine for $75 shipped on a Best Offer.
Search eBay for a used 996 TB. I got mine for $100 shipped on a Best Offer.
Search eBay for a K&N air filter, if you want to use one.
You have to reuse your MAF housing off your 986 air box or the ECU can not read the air volume correctly.
I wanted to be able to clip a 987 MAF house back onto the 987 air box so I could get more air into the motor, but that requires a tune, so I molded the 986 MAF house inside the 987 MAF housing. When I get the headers, cat delete pipes and Borla muffler, I'll get another 987 MAF house and have a tune done on the car, so all I have to do is unclip the 986 MAF house and clip in the 987 MAF house and get a bigger intake pipe.
You will want to get a plastic iron for this. Hope you have a Harbor Freight around as I broke 2 of them and just took them back and exchanged for new ones.
80 Watt Iron Plastic Welding Kit
You will also use this to cover the hole in the 987 air box. Cut out a piece of the metal screen that's included with the iron kit, melt it into your 987 air box hole, then use the plastic strips in the kit to seal the metal screen. I also wrapped the end of the intake pipe that goes to the MAF housing with the metal screen to give it more strength, melted it into the pipe, then melted the plastic strips around the metal screen.
Or get one off eBay, but be very gentle with it.
80 Watt Iron Plastic Welding Kit Bumper Repair Jaguar Mercedes Fiat BMW Ford | eBay
You will need to fill in the gap around the 986 MAF house to the 987 MAF housing. Use this as it melts when it gets hot from the plastic iron. You don't fill it up completely, just enough to seal it.
Permatex/Tube flowable silicone windshield and glass sealer 81730-1 at AutoZone.com
Get these to make it easy on yourself filling in the gap.
http://www.amazon.com/gp/product/B007Y8230G/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
You will also want to glue the bottom of the 986 MAF house to the 987 MAF housing. This keeps it in place while doing your work.
http://www.amazon.com/gp/product/B000LGT0GI/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I also used the Honeycomb air straightener so the MAF sensor could get a more accurate air volume reading. You will need remove the 987 MAF house screen and cut out the 987 plastic to install this. You will also need to trim a bit of plastic away from the inside of the 986 MAF house to get the Honeycomb air straightener to fit inside it.
Honeycomb for MAF You'll want the 75mm size
Use the clamps you took off your old Distribution T to clamp the Maf housing to the intake pipe silicone house.
This is a time consuming job, but the end result is well worth it, when you mash the throttle the car goes like stink and the intake roars.
One more thing. If you do it the way I did mine, follow Brad's advice in this post or you will not be able to mount the 987 air box with all the screw hole mounting points.
987 v 986 Air box
The hole I have circled in red will be the screw hole you can not use unless you give the air box some extra room. Take one of the blue grommets and roll pin off your old 986 box, put it in that hole then get a screw bolt that is long enough to reach the screw hole treads in the chassis and tighten it down.
I see my links have now been censored. Guess they don't want the competition to Pelican. Anyways you can take the ending number on the links, which are the part numbers. Google ECS Tuning and put those numbers into the search on their site and it will pull up the part.
