Old 01-05-2017, 08:31 AM   #1
AZ986S
AZ986S's Avatar
Not to rain on your parade, but you can get brand spanking new Meyle drilled rotors for around $75-80 per pair including shipping on ebay
also. it may be the pic, but the lower left rotor appears to have grooves and would need to be turned
Sorry
Not to sound like a dick, but these rotors are OE, so not sure you can compare the casting/design quality. I have not machined these, so off course the rotors have some slight grooving. Thickness measurements reflect that.
Make an offer.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
