Old 11-30-2016, 05:36 PM   #1
jim_hoyland
jim_hoyland's Avatar
If all you replace was your battery, you had/have a ground issue. I'd monitor to see if static comes back. Lack of AM is usually caused by a bad ground at the antenna amplifier located in the passenger side A pillar.
Search a bit and you'll see a DYI on getting to the amp and cleaning the connection.
Several years ago I did the antenna amplifier ground fix and it seemed to Have worked.
Forgot when the static returned, but it went away when the new battery was installed.
I was curious whether anyone else experienced this happening
jim_hoyland is offline   Reply With Quote
