Old 10-18-2016, 09:26 PM   #11
madmodz
madmodz's Avatar
Originally Posted by Ben006 View Post
If it happened after the plug change, recheck everything you did.
I hope it's not much!
I see that you used the piece of hose that I provided! how did it fit? Did the coil prevented it from collapsing? How did you get it straight on the AOS ?
I'm too burned out to work on her tonight. The aos hose was a little tight, but it fit with no issues. I did use the 15 degree 3" pipe that I cut down quite a bit. I also cut the elbow coming from the tb to give less of an angle. It turns to sharply in.
madmodz is offline   Reply With Quote
