Old 06-26-2006, 12:00 AM   #7
larez2
lugging the engine is a term that describes putting your engine under a stressful type of load.
The most common example is running your engine at low RPM's but in a high gear, not so much while cruising, but during acceleration - for example going from 30-70mph in 5th gear on flat ground with the gas pedal floored (a definite no-no).
it can cause piston slap - that clunky noise you often hear on beaters, and can cause the pistons and cylinder walls to wear faster - which can lead to engine failure.
HTH,
Larez2
larez2 is offline   Reply With Quote
