I wouldn't be too afraid of wheel spacer. I've had good luck with them in the past and didn't have anything go wrong. I had a set of wheel spacers on a Chevy Malibu that I had turned into a pro-touring beast. 355hp, 405 ftlbs, under 3000lbs and tubular suspension. I had 3 inch spacers on the back of that car and I use to beat the tar out of it. I completely F'd up on the boxster and shouldn't have done the things I did. I got those spacers/lug bolts off a Boxster that I had dismantled. Whoever put them on that boxster used liquid nail or something similar. I used a putty knife and tapped it with a hammer to get them off. Yes using no spacer is better than using one but I wouldn't hesitate to use spacers if you need to. Just don't be a dumbass like me. Nothing wrong with spacers. Heck even Ford uses 4-6 inch spacers to turn their front Dana 60 single axle into a dual rear wheel axle to use on one ton trucks.
Woody
