Old 04-30-2016, 11:24 PM   #1
Smallblock454
Hi,
my question would be: is the rear loose in general or only in some situations.
Is the rear loose if you
break hard on a straight line?
break hard on a straight line in combination with bumps?
break in corners (which isn't recommended but we are racing)?
you are cornering and go off the throttle?
you are cornering and go on the throttle?
you are cornering without load cycle?
Also i like to ask why you've chosen a +30 mm ride height in the rear?
Did you check the weight at every wheel? I suspect you will ave a little more weight in the rear of your Box.
In general: if you combinate more weight with a higher ride in the rear, you will always get a more loose rear.
Regards, Markus
