Old 04-19-2016, 02:47 PM   #1
JFP in PA
Originally Posted by newBgeek View Post
I have a P0197 code that keeps recurring (Engine oil temperature sensor below limit value). But my oil temperature appears to be normal. I read 82.5C after a 30 minute drive.
Does anyone know under what conditions this code is triggered?
Either an open circuit or a short to ground; could be wiring, sensor itself, or the DME. You need to check the sensor for the correct resistance and continuity, and test the wiring from the sensor to the DME for a short.
