Old 11-13-2015, 03:44 PM   #23
steved0x
steved0x's Avatar
I just started an.oil change with the 16 qt square version. The oil drained into the pan fast enough. Maybe because so much sprayed out the sides, it came down and redirected back up by the little fins, probably a quart of oil sprayed outside the boundary of the pan. I will have to try the trick with the pvc pipe because this sucked... Easily the biggest mess I have made in years
