Old 11-06-2015, 12:38 PM   #4
tommy583
98 Arctic silver 986
tommy583's Avatar
Well the main difference between the pans is that the 16QT one seems to have way better seals on the caps. The 15QT seal on the pour spout is horrible. Also the hole for the oil to go into the pan is way to small and doesn't seal. I ended up making it bigger and covering it with wire mesh. The vent cap is the least of it's problems. The 16QT also can be stored on its end, that is if the seal in the pan part works.
I'll most likely be using it on Monday. I'll report my findings.
