I have it working now. I'll see if the problem comes back (hopefully not in the rain). I removed the door panel and everything looked okay. Next I tapped on the window motor with a rubber mallet, while trying the switch. It worked. First it moved about 4", then after closing the door and lowering it fully, everything worked as it should. I guess that it is an internal contact or relay within the motor unit.
The manual was of little use, other than removal and installation info.
