Old 08-24-2015, 07:34 PM   #1
Rob175
Rob175's Avatar
Can you explain what cables or springs you're referring to? I was referring to the two tension cables with ball sockets that pop on and off in order to move the rear portion of the top in order to work on the engine. If you know of any other springs or tensioners please explain. The rest of the top looks to be fine with nothing else apparently amiss. The sides remain in the tracks so it's not that cord issue if that's what you mean.
Rob175 is online now   Reply With Quote
