Old 06-17-2015, 09:32 AM   #10
cardiffgiant
I did use a protectant from a different brand. I don't recall if it was duplicolor. I had the same concern. The Mothers kit has everything that you need to eliminate deeper imperections, but then leaves the plastic exposed to UV.
If the sealant that I used was something different, I'll grab some of the duplicolor. while the process was veyr smooth, I'm not eager to do it again any time soon.
cardiffgiant is offline   Reply With Quote
