Thread: Audi Swap
Old 04-13-2015, 11:47 AM   #17
KenDFW
Originally Posted by Lobo1186 View Post
so which axles did you use? The 2.7 axles do not bolt up to this transmission?
I used the 2.7 axles for the swap. The Audi transmission flange uses 10mm bolts, whereas 2.7 use 8mm. You can see in the pictures, I pulled out a flange.
KenDFW is offline   Reply With Quote
