Old 02-19-2015, 11:45 AM   #10
swaff
Originally Posted by CraigM View Post
Any progress on this? I don't think mine will survive being pulled and put back on.
I have a pair of headlights where the little rubber seal that goes around the whole outer edge of the outside lens was really gummy and messed up. I found that you can use marine/automotive rubber strip like this to do a DIY gasket or O-ring cord. The marine stripping like below is a little easier DIY as you just stick it on, but o-ring cord will look a little more factory, you'll just need to get some rubber cement and glue it on. I hope this helps some of you with the gummy outer rings.
O-ring (this .210" works well) - JEGS Performance Products 21603, JEGS Nitrile O-Ring Cord | JEGS Performance Products
Marine/Automotive rubber strip -
MD Building Products 19/32 in. x 10 ft. EPDM Cellular Rubber Auto and Marine Weatherstrip-01033 - The Home Depot
Swaff
swaff is offline   Reply With Quote
