The new micro encapsulated bolts already have the sealant on them. The LN instructions say to use a little sealant on the bottoms of the heads of the bolts. They also say to use the green loctite on the center stud after the nut is installed. I need to go pick up some of the green loctite.
As for the RMS, I've read something about setting it to 13mm. Does this sound right?
