Thread: A/C fan noise
Old 02-04-2015, 03:25 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by Coffinhunter View Post
Ran into questions. 1st saw no ac Vent to remove. But that doesn't matter. I removed the screws from the blower cover but couldn't get the blower assembly out.
At this point I changed strategies and went through the battery area. Cleaned what I could, and put it back together.
I went to put the blower cover back on, and now it won't fit back together. What kind of contortionist do you have to be?
Is it different on a 2003 than your car?
the reason for the fan not sliding out, is the fact that the the wires (see pic 6) and the vent are holding it.
the ac vent is behind the dashboard.
if you removed the cover, make sure you slid it back in the correct orientation, as it can be reversed.
