Old 07-19-2014, 02:43 PM   #3
Skidoo800r
Originally Posted by Davev View Post
The regulator suggestion was not the way to go. Your description points to the micro switch on the inner door handle. There are threads about getting to it. Fairly common issue.
This micro switch senses the door handle moving and drops the window, then senses the door closing and sends it up again.
I have tested the inside handle switch. It will alluminat the interior light when pulled. So in my mind that means it is working.
Skidoo800r is offline   Reply With Quote
