Originally Posted by Brad Roberts
You will be upset when you find out: the shift arrester didn't solve the problem
To properly fix your issue? You'll need a new second gear and slider, you'll need to repair or replace the tail housing
Thanks gentlmen: Based on comments, I replaced second gear, slider, and synchronizer rings for second gear. I repaired the tail housing. All back together tonight. 2002BoxsterSTransmissionRebuildDecember2011Revisio n3.pdf
