Old 06-18-2014, 09:21 AM   #2
nimblemotorsports
Originally Posted by Jamesp View Post
I believe that is the rear crossmember mounting holes. You have to have that installed before bearing any weight on the rear tires or you risk major rear suspension geometry damage. It's a big welded steel stamped assembly. You should see similar holes on the oyhe side of the cat. Contact itsnotanova on this forum to pick up a replacement.
Aha, now that I search on 'rear crossmember', no problem finding pics of it, etc.
itsnotanova been asked for help. Thanks!
nimblemotorsports is offline   Reply With Quote
