Old 05-16-2014, 11:41 AM   #1
Gelbster
I eventually found,buried on Pelican's website that this upgrade in Wayne's book is a dud.
The Cayman uses a 23 spline hub,the Boxster S is 21. I nearly made an expensive mistake there.
Reviewed by 1 Customers
Sort by:
write a review for this item
Does not fit 986 Boxster S
By Bfan, submitted October 22, 2013
Comments: I had read some where that I could use this disk on my 986 Boxster S 2001, and it would give me somewhat more bite.
It does not fit, the splines are slightly different. It is surely an excellent product for its use.
Update: Not so fast.Perhaps the MIT grad was correct?
I bought and tested a 23(yes23,not 21) spline clutch alignment tool for a 1" /19/32" bushing.It is intended for a Ford Explorer. It fits my 2001 Boxster clutch plate and DMF perfectly!
Porsche are notorious for mix&match so before you decide on this project get a cheapie tool and test.
Surprisingly the Pelican rep was terse & unhelpful on this issue It would have been easy for him to have performed the same simple test I just made -and sold an $1800 Pelican "clutch super kit" !
