Old 04-23-2014, 09:43 PM   #2
Gilles
The clutch has to be on the floor to bleed. I just open the bleeder, push on the clutch and clutch stays to the floor. then I attach the power bleeder and bleed. A pint is way too much. A couple of ounces is all it takes to bleed the slave.
If I remember correctly, the shop manual calls to leave the bleeder open for 15-20 seconds at 20+ psi...
Needles to say, you will flush a lot more than a couple of ounces... (you may want a helper to keep an eye on the power bleeder fluid level)
Gilles is offline   Reply With Quote
