Old 04-16-2014, 04:30 PM   #4
thstone
On my mobile but didn't see any spec for which type. Typically cross drilled are for S models. Pretty sure those are bigger than the base brakes?
OEM rotors are solid for the base and drilled for the S. In the aftermarket, you can find any type you like (solid, drilled, or slotted) for either model.
I use cheap "no name" rotors like you found on eBay for the Boxster and the 996 and have never had an issue. I even race them on the Boxster without issue (but they do get replaced every pad change on the racecar).
Pad selection is based on your driving. If regular street + some curves, the OEM replacement pads are perfectly fine. If you want less brake dust, go to a ceramic pad.
