No rubber sleeve to seal it to the mouth of the coolant tank. You'll have to hold it in place to use it so you'll probably need an assistant to change the mode from the compressor to the coolant bucket. Doing a lengthy vacuum test may get hard on the arms.
I predict you'll be sorry you cheaped out.
'99 black 986
