Old 02-16-2006, 01:02 PM   #2
MNBoxster
Originally Posted by RandallNeighbour
Wow. The clutch uses the brake fluid? Is this what you're saying? ...
Hi,
Yep, two separate Master Cylinders, but both draw their Fluid from a Common Reservoir located on the Brake Master. As the Fluid ages and accumulates moisture, both systems are adversely affected. Even greater reason to adhere to the Two-Year Change Rule. Hope this helps...
Happy Motoring!... Jim'99
