Thread: Head unit swap
Old 11-22-2013, 04:07 PM   #16
joejitsumd
So I successfully swapped out the head unit. I was having a problem for a while in which the radio was not receiving any constant power, so all my memory settings would get erased each time the car was turned off. Turns out the aftermarket harness had the yellow and red power wires reversed so once I swapped those connections all worked fine. In doing a search I found someone else had that problem so if anyone does a head unit swap check to make sure the harness you buy is not incorrectly done.
joejitsumd is offline   Reply With Quote
