Old 11-03-2013, 09:44 AM   #15
Boxster33
Jake, what do you recommend as the replacement interval for the Water pump and AOS?
My Boxster is a 2000 S with low Kms (42,000) with original Water Pump and AOS.
I have read that a good check for the AOS is to pull off the Oil Cap at idle and if it's difficult to remove then AOS needs replacing.
Thanks in advance.
Boxster33 is offline   Reply With Quote
