Old 09-25-2013, 09:50 AM   #20
joeyclouse
Originally Posted by rp17 View Post
The lawsuit only targets those cars because they were the most likely to fail like stated about 8%.
Can you tell us about the symptoms of your failure? How often you changed your oil? Did you have a manual transmission? Your oil change intervals and driving habits? Did they actually split the engine case to see what was the culprit?
I had an automatic with around 50K miles only owned it for 1 year bought it from car max had one oil change drove it as my daily commuter car fairly aggressively. No symptoms until when I noticed when quietly listening to it while it was idling you could here a light crunching noise. At that point the I already had the faliure the shaft was damaged and metal pieces were everywhere including the oil pan. The bearings were pitted the only good thing was the bearings stayed in place.
joeyclouse is offline   Reply With Quote
