Old 08-29-2013, 10:02 AM   #10
papasmurf
Dinoc is I believe a thicker material...need to check to be sure
as it has been about two years since I have messed with the Dinoc. The 1080 film is very thin and is basically the same film that vehicle wraps are usually done with when the wrap is printed. The film conforms to curves better than the thicker Dinoc film. Dinoc I think is only rated for interior application as well though I know lots of people use it externally but I am not sure how well it holds up. I would use the 1080 myself but that may be because I am more used to using the thinner material.
So 1080 for small pieces and DiNoc for the larger things? I'm about to order a roll of this stuff. I was going to wrap my fixie bike as test case.
papasmurf is offline   Reply With Quote
