Old 04-24-2013, 03:37 AM   #12
Skootnasty
Cracked Bank 1 cylinder head would be what I would look for. I tip my hat to you doing the heat exchanger leg work first, but it was likely to be this from day one.
Now the question is did you displace enouggh oil with coolant to scar a crank/rod bearing, or some cam bearing surfaces in the heads.
Skoot
Skootnasty is offline   Reply With Quote
