Old 03-09-2013, 09:38 PM   #10
Jaak
Jaak's Avatar
Originally Posted by Auf los! View Post
An option that has not been mentioned is to fit the Osram 65w H9 on an H7 base bulbs. The additional amperage and heat is reputed to be not a problem, and they are WAY better than any H7 bulb. I fitted these to the wife's Passat a few years ago and have had zero problems. The Passat's projectors with standard H7 bulbs were an inexplicable sick joke. The Osrams actually allow me to drive the car at night.
My Boxster has factory-fitted Litronics with the leveling function, and they are the best headlights I have ever experienced.
The extra heat will burn the lens inside the headlight units as they are plastic. Mine were burnt and I found another set that was barely used ... crystal clear, that I replaced them with. You will see many out there that are burnt ....
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
