Old 01-24-2013, 09:06 AM   #1
Johnny Danger
Johnny Danger's Avatar
Originally Posted by 3point2 View Post
Thanks for the replies. Sounds like try should work as is.
I'm going to try and put the wheels on this weekend. Hopefully I won't run into any issues.
Another question. If I wanted to have the wheels flush with the fender, what size spacers would be recommended? And where is the best place to pick up spacers?
The front offset at +57 is way high for a 986 boxster. You may in fact run into a clearance problem with the strut. Therefore, I would recommend bringing the offset down to at least +45, or more, if you're looking for an aggressive stance. As far as the rears are concerned, as Deserion indicated, the 35mm aspect ratio at a minimum will altered the speedometer calibration. That aside, if you're looking for a more aggressive fitment on the rear, you could easily lower the offset to +40 without any issues.
