Old 01-18-2013, 08:36 PM   #1
seventythree
FS: Misc. Parts - cheap
I need to clear out some space on my storage shelf, so here we go:
1) Used, cracked coolant tank. Scavange some parts or play around with repair techniques.
$5 + shipping
See bottom of the post for pics
2) SOLD - Good, used AOS. Replaced as a preventative measure when replacing leaky coolant tank.
$20 + shipping
3) SOLD - Good used oil filler tube. Replaced as a preventative measure when replacing leaky coolant tank.
$5 + shipping
4) Non-S oil cooler. Perfect - replaced with S oil cooler.
$30 + shipping
5) Non-S radiator hoses that go in the front wheel wells, left & right. Replaced when installed center radiator.
$5 ea. + shipping
6) SOLD - Good used non-S Dual Mass Flywheel. Cleaned up; sanded the friction surface; checked for spring back; ordered new one; turned out to be the same with spring back test; called LUK tech support and was told both flywheels behaved just fine?!
$50 + shipping (warning - this thing is heavy)
7) SOLD - Brake cooloing spoilers, perfect - Replaced with GT3
$5 for the pair + shipping
seventythree is offline   Reply With Quote
