Old 12-29-2012, 08:10 AM   #1
Meir
1999 base
Meir's Avatar
Ok that’s the way it goes.
Remove the door rubber seal.
With your hand, fill the top of the kick panel. You will notice a plastic tab that holds the carpet.
Lift the carpet off the tab, and gently pull it away.
This is the location of the tab:
As you can see, the carpet is glued to the plastic panel, so just peel it off, and remove the screw that holds the plastic panel.
Now you have access to the wires from inside the car.
