Old 11-17-2012, 04:56 AM   #5
Meir
1999 base
Meir's Avatar
Originally Posted by kjc2050 View Post
Did you ever succeed in quieting it down? Mine seems to make quite a racket on (bumpy) city streets...
The lens will be easier to remove if you remove plastic cover first.
Gently remove it using a plastic prey bar.
It should pop out easy.
As an FYI, there are plenty of plastic pray bar kits on eBay.
It's a very inexpensive tool, and must have, if you are working on your car.
If you have a rattle noise, it might not be seated fine, or one of it's locking tabs is broken.
As far as I know, it's not an expensive part to replace.
