Old 10-08-2012, 09:05 AM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by jdilbeck View Post
How do I tell if the brake booster vacuum line is leaking? My brake pedal sticks in the downward position and I sometime have to raise it with my foot. I believe is is either the booster or vacuum line. I have a 1999 Boxster. Any help would be appreciated.
that is not a leak you have. when air leaks out of booster line, it will be hard to apply the brake and not the other way around. if i was you, i would definitely have the brake master cylinder and booster checked.
